928 S4 interior lights + sunroof
Hello,
My 928 S4 interior lights are not working, when I turn on the exterior lights the only thing that illuminate inside the car are the p r n d gear selector in the instrument cluster.
Everything else is not "lighted".
Also the rear end of my sunroof is lower than the front, its not aligned and when driving quickly I hear air sound inside. how can I fix those remedies with my car ?
much appreciated.
much appreciated.
I would suggest you purchase a copy of Jim Moorehouse's 928 Technical CD consisting of 3 CD that contain all the information for you to fix your problems or any other problems. These CD contain the Work Shop Manuals, electrical drawings for every model and much more.
Jim is a member of this board, so I believe you can purchase direct from Jim or purchase a copy from 928sRus.com
Also remember the "search" function is your best friend and you need to put the model year of your vehicle as per my signature, as there were changes every year.
Received 1,327 Likes
Here's a good site for some info on the sunroof.
http://www.kondratyev.com/porsche/te...or/sunroof.htm
