Clutch master Designer.......
doing a complete system with new parts and Gregs hose..... i just wanted to say,
That whoever designed the MC location and accessibility needs to be dragged in to the street and beaten with a rubber hose (a long blue hose would work and be appropriate)... that is single handedly the hardest thing i have done on this car... and i have not even installed it yet... i did a bench bleed.
I am dreading doing my 79 been procrastinating on it a month already I know your pain... seen a post about installing the new one with the down tube already attached for a handle and one screw with the head cut off installed on the mounting flange to pull the new one into place..... I have yet to try this.... don't forget to put on the blue hose before installing it...
Team Owner
to make things a bit easier take 5 mins and loosen the 4 nuts holding the brake booster this will allow some extra clearance if still no joy remove the brake MC then remove the booster
