944 turbo S MO30 (928S4) Brembo Front and Rear Calipers on 84' 928S
I am pretty sure I know the answer to this already, I just want some clarification as I know these will fit my car up front with billet adapters, but will the rears bolt up as well? The reason I am asking is that I have a line on front and rears as a set for about what fronts usually go for.
They are just S4 brakes so the rears bolt up with a 5mm spacer. Use S4 bolts.
Are you using early spindles? From what I am told the S spindles don't work with the adapters.
Good luck on your swap
