928 Forum 1978-1995
Sponsored by: 928 Specialists
Timing Belt Guide Delete
Old Oct 4, 2013 | 05:25 PM
Avar928's Avatar
Avar928
Default Timing Belt Guide Delete
This is for an early 86 928S 32V Auto.
Would I have any issues deleting the timing belt guide pulley located directly underneath the crank gear?
Mine doesn't look like the belt ever touched it. Porkentensioner being installed too. I couldn't get the whole unit off because it had rusted itself onto one of the pins but I managed to take off the pulley from the assembly. I had to take off the rear belt cover to get to the oil pump.
Picture from Dwayne's Guide below:
Old Oct 4, 2013 | 05:32 PM
the flyin' scotsman's Avatar
the flyin' scotsman
both my 928s have a Porkensioner with the guide deleted......no worries at all after 1000s of kms
Old Oct 4, 2013 | 05:38 PM
Avar928's Avatar
Avar928
Thanks. I'll try one more time to get that assembly off otherwise it'll just be stuck there without a pulley. It's annoying to have on though. I ended up cracking the rear cover trying to get it around the assembly.
Old Oct 4, 2013 | 08:19 PM
davek9's Avatar
davek9
+1
Old Oct 4, 2013 | 09:16 PM
ROG100's Avatar
ROG100
Basic Sponsor
Trash or desk ornament.
Old Oct 5, 2013 | 10:44 AM
Herman K's Avatar
Herman K
Default Can be an essential life saver..
The guide can be a life saver!
When you us a Porken tensioner you won't get an early warning for a slack running TB.
Which may be due to the oil pump gear starting to come loose on the pump shaft.
The guide will support the belt at this instance, keeps the belt in its place on the crank gear and gives you some more time to shut down the engine before
disaster happens.
Ask me how I know..
