968 Steering Wheel
It is for a none airbag car my wheel has some damage to the stitching I am looking for an upgrade I thought maybe a later airbag wheel or a club sport wheel might be an easy option.
Administrator - "Tyson"
Not sure about the 968.... the non-airbag 944 steering wheels use a VW hub size, which is smaller than the 928.
Basic Sponsor
I just supplied a 968 Sport Steering Wheel (non airbag) to a customer and it looked identical to the 928 sport wheel, however the dia/splines were different.
944/968 has smaller diameter shaft to the 928
Thanks for that Roger I guess its going to be more complicated! I have some details on how to fit a 996 or Boxster airbag wheel but it involves changing the clock spring? Has anyone done this are the electrical connectors the same on the clock spring?
You can change the basket and splines by grinding the heads off the 4 rivets and using your old basket and spline from the old steering wheel. You can re rivet the new basket on or I just use bolts with lock washers and lock nuts
