help.. cannot get torqe cover off
Finally getting to the rivet rattle problem on my 87 s4. Everything is apart but cannot separate the cover from housing. PB blaster, wd 40 no help. Been at it for 3 hrs. Is there something I am missing?
all suggestions welcome.
thanks
tried to download pics from phone
thanks
Team Owner
whats a river rattle problem,.
Umm yeah a few pictures would help to figure out what your up to
I don't understand what this thread is about
He's talking about replacing the RIVETS with bolts. On the TC flex plate to TC.
Remove all the rivets and the pinch bolt for the rear pinch sleeve.
The converter should be marked for orientation to the flex plate to ensure no new vibrations.
Actually separating the flex plate from the converter can be tough as the slip fit piece in the center can become rusted into place. Try to rotate the flex plate on the converter and wiggle it forward it will eventually come apart.
Team Owner
be careful with this so you dont pull the torque converter out of its bore
Guys, got home #$%# computer froze up while I was upgrading to windows 7 ultimate. As u can see by the time of this response and the fact that I am still using my smart phone..it is still down. Yes I have pulled the TQ housing to replace the rattling rivets. The TQ looks like a biscuit and I am having problems removing the cover to expose the riveted plate.
IT rotates fine just will not separate. I will try again tomorrow. Thanks for your comments.
Lon
Lon
DONE AND PUT TOGETHER. OVERNIGHT SOAKING IN PB BLASTER DID THE JOB AND ALLOWED US TO REMOVE THE T/C HOUSING. USED 3/4 IN. 5/16 BOLTS WITH LOCK WASHER AND RED LOCTIGHT. REPLACED THE BEARING AS WELL. NO RATTLE, ON THE ROAD AGAIN!
LON
LON
