Windows and sunroof don't work
Hi all, does the sunroof share share the same relay as the power windows? Both windows and the sunroof will not operate, power seems fine to everything else, including the rear wiper. Wondering if they share the same relay or if I should be looking somewhere else. Thanks.
Team Owner
click on this, https://www.928gt.com/default1.htm
then up top on the right view 2,
then on the top left tips and links,
then click fuse relay chart
hi Stan, can't find where sunroof gets mentioned in relay chart, but also found out that fresh air blower isn't working, but defrost switch activates the blower. So what's out, both windows, sunroof, and fresh air blower. By chart that would be relays VI and X but separated by VIII relay for defrost which is working. Car has been sitting with battery disconnected for a long while, but everything was working when parked doing timing belt and such.
Here's a little more info: I can hear (with my mechanics stethescope) the relays ping when the key is turned on. So now the question is what do these components share that would cause a common failure?
This should be a little more clear.
http://928intl.com/repair/Relay/earlyrelay2.htm
The windows do not share a relay with the sunroof or a fuse.
Just as usual clean all ground points and check for corrosion on the
fuse panel. The switches could just be worn out and need replacement.
The issue with the A/C is the resistor pack. It is located inside the HVAC system
behind the evaporator, you need to take off the blower motor to gain easy access to it
and remove the plug that goes to it (similar to 14 pin), unscrew it and pull it out.
Its part number is 928 616 101 00, good luck.
This is the relay diagram I have a printout of. Still don't see any mention of sunroof. Window switches are two years old, replaced two years ago at Sharktoberfest. Everything worked when the car was parked, all maintenance was front of engine, with power disconnected at battery ground. Perhaps I will try replacing relays as a start, wouldn't hurt to have a couple spares if they prove good.
Team Owner
I would clean the fuses and relays before replacing anything
Electron Wrangler
Fuse 14 for the sunroof and fuse 15 for both windows - test the top fuse connection (can do with the fuse in - on the ends of the fuse look for the litttle cut out windows...) should be powered with accessory/ignition on - if not its the relay.
If the blower also doesn't work on the max setting (4) then it certainly isn't only the blower resistor pack - so don't order one yet...
It is possible the Blower Relay (relay X in this case) is bad - swap with the horn (if the horn worked before)... what happens?
Alan
Electron Wrangler
Speed 4 is directly driven only from the switch - you can unplug the resistor pack and speed 4 will still work.. so if it doesn't work something else is going on.
Doesn't mean the resistor pack couldn't also be faulty - but it can't be the only thing - simpler cheaper things should always be investigated first.
In this case though I think the resistor pack is likely just fine...
Alan
Team Owner
Dennis on a car that has been sitting for along while its quite possible for moisture to invade the CE panel,
and this can cause corrosion to form ,
so yes fuse cleaning should fix a lot of electrical issues that you not otherwise consider
Note from your post.
Electron Wrangler
Alan
