Center console side cover installation
Quick question...is there a trick for getting the side panels installed for the center console? I am having a bear of a time getting them installed. There is a gap in the drivers side piece should slip onto a ledge next to the shelf however I cant seem to get this lined up. They were off of the car when I purchased it so I don't have any dis-assembly reference.
thanks
thanks
First, put drivers seat bottom completely down and back. Then line up slot to shelf first, then gently push and wiggle into place. Once almost completely in place, then worry about getting it tucked under edge of the center console. The last motion is more like a roation of the aft end up more so then a slide movement. At least that's what works for me.
thanks
thanks
I also find it easier to do when you've removed the parcel shelf on each side. 4 nuts on each and then you don't have to jimmy anything. The shelf and the side panel both share the metal hanger next to the console
Tom
89 S4 Auto Black/Linen/Grey Piping
Tom
