Mystery switch....
Does anyone know what this switch is for? Initially I thought is an aftermarket switch fitted, but I removed the door cards on the weekend and the switch is exactly the same as is used for the electric mirror (but only have 2 wires connected to it). Also, lifting the handbrake cover a bit to see what is going on underneath I can see it is really well fitted and appears to have been done at the factory. The wires lead to the rear of the car but I have not yet had time to remove the trim to see where they run to…. Played around with the switch but appear to do nothing…..
Car is a 1991 Euro GT
Team Owner
how many rear fog lamps does the car have? maybe this turns one on or off after the the one is actuated
Team Owner
maybe its a brake light cut out switch
I would like to find out as well.
Someone wrote here a while ago that it was a factory alarm interior sensor override switch; meaning you could have the windows open but still have doors, hatch, bonnet(hood) alarmed. I don't have the factory alarm anymore so no way of testing this.
Do you have the factory alarm?
Ok - not related to the rear fog lights - when I switch the fog lights on it illuminates in both rear lights but flicking the switch does not turn one of them out....
Yes, UK RHD car - nothing in the owners manual either....
Oliver - do you have one fitted to your 1991 S4 as well? I have a factory alarm installed but no longer working
I found my notes - proper name is "vent" switch. A UK user (rawki ?)found the description in his manual a few years ago.
Team Owner
good to know about the alarm sensor cut off switch
