12 pin cruise connector Pin assignment
Today was cruise fix day. everything went well thru the diagnostics until I got to the 12 pin connector on pass side of console.
Long story short, when I pulled connector the housing separated and now I have 12 loose pins/wires hanging there.
I have searched thru my WSM and wiring diagrams but cannot locate a pin assignment. What color wires go into which number hole in housing.
Any help appreciated. thanks
I did manage to figure out the wire locations in the connecter housing based on the wiring diagram in the WSM. The cruise has never worked properly since I bought the car years ago. I just assumed nobody had been inside that plug before..... I was wrong !!! Several of the wires where in the wrong location in connecter housing. Anyway I repositioned the wires to the proper location and plugged it into the cruise control brain box. The dang thing works now !!!
Anyway for anyone else having odd trouble with the cruise, I wrote down the wire color codes and location number in the 12 pin plug
Positions 1,2,4 are blanks in my 1983 plug
Position 3 = white
position 5 = double black wires
position 6 = Black/red wire
position 7 = brn/blk wire
position 8 = brn/blk wire
position 9 = yellow wire
position 10 = blue wire
position 11 = brown/red wire
position 12 = brown wire
Note there are two brown/black wires in positions 7 & 8 If you have trouble with the pin 7&12 test procedure in WSM. (not proper voltage reading ) swap these two with each other and it should test OK.
ANYWAY HOPE THIS IS SOME HELP FOR SOMEONE.
Position 3 = white
Vegas, Baby!
Bout time ya fixed it!
Vegas, Baby!
