928 Forum 1978-1995
Sponsored by: 928 Specialists
sometimes no reverse
Old Aug 25, 2013 | 05:30 PM
rcrone928's Avatar
rcrone928
Default sometimes no reverse
Hello Men. recently getting no reverse or slow to go into reverse. If I put lever into drive and then into reverse it will engage. Could this be a sign I need to replace B3 clutches or, could it just be a minor cable adjustment. Just wanting a simple fix before I decide to pull the tranny. The car is an 83 4spd with 120k on the odo. Thanks for any advice in advance.
Old Aug 25, 2013 | 05:56 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Verify the fluid level.
Old Aug 25, 2013 | 06:30 PM
ammonman's Avatar
ammonman
If the fluid level is correct see if you can reverse up a modest incline. If it won't then it's time for B3 to be refreshed.
Mike
Old Aug 25, 2013 | 06:41 PM
rcrone928's Avatar
rcrone928
Thanx for the quick responses. Once reverse engages I can back up a modest incline and the fluid level is a bit higher than recommended when hot. Can the B1 brake band be adjusted? Like many folks just trying go the easy route first.
Old Aug 25, 2013 | 06:48 PM
jpitman2's Avatar
jpitman2
This is not uncommon in the 3speed box - reverse band adjustment can help - I need to do this sometime soon. Do a search on this topic.
Dont know about 4 speed.
hjp 83 Euro S AT 55k
