Block coolant plug
Does any one have the part number for the crush washer for the 2 block drain plugs on a 16V ..... I looked through the PET and can't lay my eyes on it... I know its there, im just looking at the wrong place.
If you are not buying from a vendor who can give you the right part, take the bolt to Autozone/lowes/anyplace that might have a copper or aluminum washer and see what fits. Install and be happy.
Be sure to use anti-seize on the bolts.
Team Owner
when you tighten the block drain remember,
they are only drains so just past snug is how tight they should be
DO NOT use a torque wrench to tighten these plugs
Basic Sponsor
Be sure to buy the 900 123 055 30 as it is a special size sealing washer - not cheap but it works as it should do.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Chronic Tool Dropper
I seldom disagree with Stan, but I'll take the chance now.
The aluminum washer expects a certain amount of pressure to seal to the bolt and the block, and anything that interferes with a smooth face on either will risk a leak. Meanwhile, the bolt itself has straight threads, not tapered 'pipe' threads, so we don't really expect the threads to do any sealing. The path of leakage is around the back (unloaded) side of the thread, in the gap between the back of the bolt thread and the front of the block thread. Coolant that passes all the way along through that path then comes up against the aluminum washer, sandwiched between the bolt and the block. Any scratches in the block, the bolt face or either side of the washer risks a path for coolant to escape.
I propose that folks use teflon pipe thread sealant paste on the threads, and on both faces of the washer. The paste fills the gap at the back of the bolt threads, and also fills any gaps from scratches or other imperfections on the block, bolt or washer surfaces. The Teflon paste is also a lubricant, so less torque is required on the bolt to get the same pressure on the washer. I guesti-calculated 12 lbs/ft for mine. For years now (annual coolant change times sixteen years of ownership, plus more than a few guest cars) I've been using and recommending this method. I used Hylomar for a while, then switched to the Teflon thread sealing paste, both with excellent results. No leaks, absolutely painless bolt removal for coolant changes, etc.
Little tube of the stuff, or a can with a brush (lifetime supply) is in the plumbing aisle at your favorite hardware or home center, like Home Depot or Lowes.
Relating my own experience, your results may vary, no animals were harmed, etc.
