CL: Lower timing belt rollers 928.105.067.00
Saw this in my local CL. I think he want $70 each.
Hi, I have seven new in the box genuine Porsche replacement timing belt
guides that I am letting go at a fraction of the cost.. These retail for almost $200 each... John 404-275-9926 call or text.. I prefer text
timingbelt guides
timingbelt guides
He called me directly and I said thanks but no thanks.
it only comes into play if the belt loses its tension.
it will keep the belt from jumping the crank gear,
it can also be used as a tell tale as the roller will touch the belt along its center,
and if when inspecting the belt you see strange marks on the belt then its an indication the belt is loose.
