Best place for four wheel alignment
#31
The rack on the Hunter is wide, I think with a raised outer edge. The car is low. The rear toe adjuster has sides. You can't get any normal torque wrench, or a normal open end wrench even, onto the adjusters. That's the problem the alignment guys have. I bought a special wrench just to enable tightening them while on the rack.
Heading in for an alignment and would like to provide a picture of this special tool/wrench that allows for rear toe adjusting.
Anyone?
#32
Sorry, was traveling and had limited access. Posted it a few weeks ago.
Below is a wrench that makes it easier to tighten the rear toe eccentrics while on the Hunter. Got it done.
Does not measure torque, you may need to scribe the final orientation and make that final check at home on jackstands.
https://rennlist.com/forums/928-foru...ing-pivot.html
