928 Forum 1978-1995
Sponsored by: 928 Specialists
Speedometer/odometer
Old 08-05-2013, 11:04 PM
aebs
aebs's Avatar
Default Speedometer/odometer
2 days ago, I was on the freeway and my speedometer/odometer just stopped working. It's around 112,000 miles. I assumed it was broken.
Yesterday I started driving and the speedometer started spiking up and down. Then it went close to where it should be, but wobbly. Then to zero. It repeated this sequence a couple times. Then it started working fine.
Today I drove it and it worked fine too. Any ideas what might be going on here?
Old 08-05-2013, 11:20 PM
WICruiser
WICruiser's Avatar
A loose connection someplace in the circuit between the sender in the transaxle and the head unit. Lots of opportunities. Have you done anything recently that may provide a starting point to look?
Old 08-06-2013, 08:16 AM
9two8
9two8's Avatar
Could possibly be the odometer gear wheel about to expire ?
Ken
80 928 S
5 Speed
UK
Old 08-06-2013, 10:18 AM
76FJ55
76FJ55's Avatar
most likely a loose connectin somewhere in the system. the ODO gear typically won't effect the speedo function.
Old 08-06-2013, 11:45 AM
joejoe
joejoe's Avatar
Check the connection in the spare ire well.
Quick Reply: Speedometer/odometer
