88, 928s4 - HCV changed no cold air still
Jumper the clutch wire to the 14 pin post to see if you can get the compressor to turn on. If if does your relay from the hvac head unit doesnt have enough power to turn compressor on.
If you do that test checking for 12V at the freeze switch, then you can't assume the relay in control unit is ok unless you put a load (like a headlight bulb) between freeze switch and ground point and can confirm voltage does not drop dramatically.
When the relay fails it may pass small currents (a decent multimeter will draw less than 1 milliamp when measuring 12v), but tyere will be a big voltage drop when you demand current similar to the compressor load.
Your problem is either:
relay in head controller
corroded contacts in freeze switch (happened to me - easy fix)
Seized compressor/burnt-out electric clutch
Keep us posted!
Keep us posted!
Well I tried jumpering the freeze with, I basically disconnected both and jumpered a cable between them, then tried the AC again and nothing, I see the RPM drop when I press the AC button but no cold air still...now I need to jack up the car and check the power connection to the AC compressor...
Any other possible easy ideas to try ; )
thanks...alot brothers...!
Sniper
Sniper
Sniper
Sniper
