Window regulator
My passenger side window suddenly became inop. The motor turns, the switch seems to work fine and the glass is loose in the door but is stuck fully down. I'm thinking a failed regulator, or is it possible the glass is off the track?. Is this unit rebuildable, or just replaced? I will have the door panels off soon for new speakers, but is there a published procedure for removing a regulator from a 82? Thanks.
Have look through this guide, it may help ?
http://www.kondratyev.com/porsche/te...dy/windows.htm
Ken
80 928 S
5 Speed
UK
Ken
80 928 S
5 Speed
UK
Rennlist Site Sponsor
One possibility is a failed roller on the end of the regulator arm. The roller can be replaced fairly cheaply. You will need to remove the regulator from the door, drill out the end of the rivet that holds the roller, replace the roller and rivet and peen the end of the rivet, then replace the regulator in the door.
WYAIT (While You Are In There) check and lubricate everything. You can replace the nylon collars that run up and down the guide post, or you can add a few nylon wire ties around them to take up any wear.
Basic Sponsor
We stock the roller and pin if you need them.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
