FS: S4 5-Speed conversion parts
I have a mostly complete 5-speed conversion setup from an ~120K mile 88
What I have:
88 S4 5-speed trans (open diff)
Rear subframe with mounts
Torque tube with shifter linkage (from 93 GTS - I would replace bearings)
clutch pedal assembly
firewall sheet medal
flywheel
clutch slave
clutch master
I may have a spare used clutch line from the master to slave, but not sure. Also, not sure I have spare clamps for the torque tube or the short spline shaft from that rides in the pilot bearing, but if there is interest in the whole kit as above, will look.
$2200 or best offer for the trans. $3500 or best offer for the complete swap (with the short input shaft if I can find the spare) $3200 without the short shaft.
I was keeping to swap my 89 to 5speed, but looks like I will have a native one in the stable soon. Need more space in the garage, help me out.
Hans
What I have:
flywheel
clutch slave
clutch master
Hans
