Interior color code info, again
Sorry if this a broken record, but I can't identify the proper seat color on my 82 5 speed for redyeing. I called a Porsche dealer and they told me the interior code through the VIN information was YT. I couldn't find anything with this code, any suggestions? I thought the color was cashmere beige and the dash and headliner the standard brown leather, but now who knows? If I can't find a proper code, I'm just going to redye all the seats and center rear console with Leatherique cashmere beige and be done with it. I think the standard brown for everything else is correct. Thanks!
Pics would help identify whether it is, as would a VIN number (462 is the option code for Weissach edition).
The interior code the dealer gave is most likely a production code for the interior color scheme, not a code for a specific color. All the interior component color codes in PET are three digit alpha-numeric codes. You can sometimes make an educated guess using the color listings for different components in PET and color samples through the process of elimination.
Mike
Mike
Cottage Industry Sponsor
Based on the picture you sent, I still believe it is brown with grey beige. But I cannot say this with 100% Certainty, and you need to be aware that the color is probably faded by now and might not look exactly like the samples you see.
The VIN is WP0JA0926CS822168, hopefully someone can decipher the colors.
Plenty of other cars have two-tone interiors specified originally - however, the interior option colours aren't specified in the usual 3-digit option codes found on the rear hatch sticker.
Two digit interior code tells almost everything needed to know what colors and materials interior was made with. Only small problem is that those codes are not generally known and available. Sometimes it helps to search other Rennlist areas. Same codes were used for same MY for different models. For example GTS code explanations can sometimes appear in 968 threads.
