928 Forum 1978-1995
Sponsored by: 928 Specialists
Defrost actuator
Old 03-22-2020, 03:37 PM
Bigfoot928
Bigfoot928's Avatar
Originally Posted by SeanR
I usually can replace the defrost actuator with out removing the pod. Granted, getting the new actuator in and the cap on so it seals can be a trial, but it's not necessary to remove the pod. You can access the top of the cap with the pod in the upper most position and the lower while hanging out upside down under it.
Take the vacuum line off, pop the cap out of the way, disconnect the arm on the defrost assembly and pull it out. Be gentle putting the new one in and pay particular attention to the diaphragm rubber ring, if it's not all the way around the cap do not force the cap on. Doing so may destroy the diaphragm.
I have no idea how you do this, especially on the airbag dashes. I have the console, the pod and the one bolster out and still can’t get the cap off.
Quick Reply: Defrost actuator
