Don't Ban me - why not an after market radiator?
#136
Received 1,543 Likes
Not quite.... There's a radiator shop on the East Coast that will replace the end tanks ... and provide a warranty on the work. I don't remember their name off the top of my head, but I'll search it out when I get home. I've been involved in having end tanks replaced three times. This last one was the only shop that succeeded and provided a warranty. (And before you ask: 10 months to go on the warranty. Ask me the question this time next year.)
#137
Basic Sponsor
We have a shop here in DFW called "Clicks" and they have been replacing end tanks for a long time and seem pretty successful at it. They have the Behr press.
#138
Administrator - "Tyson"
#139
Hi,
we in Belgium do things differently. I had an original Behr radiator but due to a problem with lever of my headlights, the lever perced itself into the radiator.
Repair at a local craftsman who prepares also radiators for race cars, was not possible since it was aluminium with very narrow holes/tubes and thus too fragile.
Solution : make the same radiator in cupper, based on the original frame of the Behr radiator.
Advantage : better cooling and repairs afterwards are possible.
Price paid : $600
I've never had better cooling before. So I am really pleased!
kr
Gerrit
Price paid : $600
kr
Gerrit
#142
Developer
Aftermarket aluminium radiators are historically fraught with issues and contrary to what some suppliers say they are not plug and play. Often they are wider than the stock radiator which causes fitment challenges especially if you plan to mount a SC.
Our radiator will fit our supercharger kits. Our radiator cannot be used with Murph's SC kits.
We have 9 models now, where we started 4 years ago with 3. The early ones required more fitting to the car - but since we went to 9 different designs for every fan shroud and cooler combination, they are very drop-in ready.
And the "fraught with issues" comment. Hardly that. That's already been discussed in this thread and the failure numbers are published.
So when I see "why hasn't anybody made a good cost-effective replacement for the 928?" I say "we have". I suppose they could be cheaper if we went off-shore, manufacturing them in the USA costs us a little more, but I will not substitute quality for price on this. I don't really think you want us to, either.
#143
Basic Sponsor
#144
For the record, I have one of Carl's radiators and it dropped right in. Absolutely no mod required. With the Canadian temps dropping, the thing is running so cold that it has a piece of cardboard covering the bottom half. With that I am now getting 210 degrees F at the water bridge and heat in the car. It never got down that cold with the Behr. All I want now is for it to last at least 10 years. For me that's good enough.
#146
#147
Cooling system refresh done recently: Brand new T-stat, rad, rad tank, Ford dual fans,new seals IN the bridge, all new hoses, entire system flushed, 70/30 distilled H20/glycol + 1 bottle water wetter and new Flex-a-Lite variable speed controller.. In the summer I was having overheating issues. Now, the car is heating up properly and the Rad Fans will come on at slow speed @205 degrees at the upper hose). In the city all is well but when I hit the highway, it runs too cold. Upper hose runs around 185 degrees F and dash temp shows 80 degrees C (176 degrees F). With the cardboard at the lower half, I get back the 200 degrees at the upper hose. I have pictures but that would be hijacking this thread.
Thanks for the comments.
P.S. I chose 70/30 mix for max cooling because car is stored in a heated underground garage in about 2 weeks until spring.
#148
Basic Sponsor
I just bought a totaled 87 and it has a new radiator in it. Aluminium and made by a company called "Howe". Anybody have any experience with this company?
#149
#150
Friend has used Mustang alu radiator in his GT for few years with little modifications to it. Its slightly taller so factory upper mounts will not work unless both upper and lower rubber is changed to thinner ones. Fit is close enough that I wouldn't think twice about using one if $$$ is major consideration and end tanks are not needed.
