Removing catalytic converter
My cat is buzzing and I think the interds are going bad. Anyway, if I cut out the cat and replace it with a straight pipe is there a source for this with a o2 sensor welded in? Thanks
Sorry, my bad. I have a 82 5 speed. I just changed the three exhaust gaskets while I was under the car and now it is buzzing. I will check all bolts before doing any cutting.
Administrator - "Tyson"
Do it the right way. Install manifolds from an 85/86 along with this Y-Pipe:
https://rennlist.com/forums/928-foru...l-y-pipes.html
The absolute best power gain for the money with a 16V 928.
