Glycol or Water; which is the better Coolant?
#31
I have to differ on the Water Wetter, go look at the black sludge that has accumulated in your reservoir tank after adding it. I can't imagine how bad it looks inside the rest of the coolant system. I've not had that issue with the Royal Purple version.
Just my personal opinion, run distilled and G-05 and a properly running cooling set up will have no issues or any need to add stuff to it.
#33
I had thought about using Water Wetter as a lot of people here seem to use it, but then I read a few forum posts on the web about it causing sludge so have decided to avoid it. I don’t have an overheating issue so why take the risk of mixing things.
#34
#36
