928 Forum 1978-1995
Sponsored by: 928 Specialists
help - what is this part?
Old May 7, 2013 | 11:58 PM
MFranke's Avatar
MFranke
Default help - what is this part?
I recently did my motor mounts and found this rubber part on my garage floor under the front of the car. It is a few inches across and looks almost exactly like the rubber weatherstrip that runs across the top of the firewall lip in the engine bay, but shorter. I want to install it back in its proper place. Does anyone recognize it?
Old May 8, 2013 | 01:39 AM
joejoe's Avatar
joejoe
Not sure but is it supposed to go near the hot post?
Old May 8, 2013 | 02:00 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
coulda been a piece of scrap that fell into the car and was left for you to find
Old May 8, 2013 | 03:30 AM
928Myles's Avatar
928Myles
I vaugely remember something like that back near the starter motor - can't be sure though.
Myles
Old May 8, 2013 | 03:36 AM
FiveElements's Avatar
FiveElements
Myles ^^^ is right. I recall having one of those near the rear starter areas on the cross support that holds the motor mount. I can look again and see if I can get a photo of it on the car
Old May 8, 2013 | 08:33 AM
MFranke's Avatar
MFranke
I did remove the starter and cleaned the area. Maybe it fell off from somewhere around there.
Old May 8, 2013 | 08:36 AM
MFranke's Avatar
MFranke
Another clue is that it appears to have cosmoline residue on it.
Old May 8, 2013 | 10:11 AM
ROG100's Avatar
ROG100
Basic Sponsor
Sits on the edge of the oil pan below the starter IIRC
Old May 8, 2013 | 10:48 PM
MFranke's Avatar
MFranke
Thanks for all the replies so far. I'm still stumped.
I inspected the starter and oil pan area. There is another black rubber bit glued on the oil pan above the starter, and it's attached on there (mystery to me what that one does). Is that what folks are thinking of, or am I missing something? The rubber bit that I found loose and took a picture of is slightly larger (few inches) and of the same shape/width as the firewall weatherstrip.
Old May 8, 2013 | 11:14 PM
FiveElements
I'm going to Bill ***** later next week. I'll see if I can snap a photo of where it goes
Old May 8, 2013 | 11:21 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
loot at the pan. it is glued to one of the ribs to stop the hot wire from rubbing.
Old May 8, 2013 | 11:22 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
check the pic
http://www.ebay.com/itm/83-PORSCHE-9...792f3b&vxp=mtr
Old May 8, 2013 | 11:41 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
I know where it goes ,
this piece goes on the rear edge of the front cross member its holds the wire bundle off the cross member edge.
The oil pan has a smaller piece thats glued to the rib above where the wire connection is so it wont short out
Old May 9, 2013 | 09:59 AM
MFranke's Avatar
MFranke
Ah. Great - I will stick it on the crossmember then! Thanks!
