Power steering ATF capacity?
Hi folks. I have completely drained my power steering ATF to fix some leaks. How much ATF will I need to refill the whole system? It's a UK 1990 S4. The technical spec says "Approx. 0.7 ltr" but this doesn't seem like enough. Maybe 0.7 ltr just seems like a lot more when it is spread all over you, your car and your garage.
Cheers
Cheers
Ok 0.7 it is then. I had wondered if the 0.7 was perhaps the reservoir capacity. I'll probably buy 2 litres as it won't hurt to have a bit spare in case of leaks. Not that there will be any!
Many Thanks
Many Thanks
