Heating problems
Hi !
I have some problems with my heating element.
I can only choose between full heat or full cold stream....
I have tried to change the Heater Valve but no difference.
Any tip to what i can do ?
Rennlist Site Sponsor
Most common cause is a poor connection at the outside air temp sensor located below/behind the left headlamp. This sensor is one item on the temp control string - outside sensor, inside sensor, temp control lever to temp control box on side of the main HVAC box (buried by the driver's right ankle).
If you go to our website, then Tip & Links, then Wally's World, then HVAC, you will find a paper describing the system.
