Does anybody know what this is?
With all the smart people here Porsche should hire most of you as consultants. Enclosed is a picture of a connector or test port on the right side of the engine ( drivers side) at the back to the left of the master cylinder. I am having more fun with the 928 working the bugs out then the all the fun I had with my 996 I purchased so many years back or the Maserati after that Note: (If you really, really like wasting money Maserati is the car to own )There is a lot of enjoyment in buying a car that looks local car show ready car.... with tons of things not working as were the PO gave up, sold cheap ( Like new HDTV cheap) then fixing those issues one at a time. Thanks for the help
That is the unused test port for RPMs that is normally mounted at the rear of the driver side fuel rail. It actually sometimes has a cap that keeps the sand , dirt , and crap out of the pins.
Last edited by soontobered84; 04-24-2013 at 12:59 PM. Reason: correction for posterity
Team Owner
Thats a connector for the RPM sensor,
it was used at the dealer to check the RPM while being serviced.
There are 2 crank position sensors this one is for service diagnostics only ,
the other CPS sensor is used for sending a signal to the computer, so to run the ignition/injection system
