Hose, cam cover to throttle?
I'm looking for the part number for a hose that runs from the passenger side cam cover to the base of the throttle on an '85 928S. Looking at the catalog I can't find this hose on either the cam cover detail or the throttle detail, but it connects to 928 107 733 00 on the cam side, just labeled as "adapter". Anyone know where I can find one of these?
I'm also looking for an assortment of the spit wire guides/clips used to retain cables running around the top of the engine. Some are about 6mm others smaller, they're split with barbs on each side, you clip then around a wire, squeeze them and stick 'em in a hole. I don't even know what they're called but I need several of them in assorted sizes.
Thanks,
Scott.
Thanks,
Scott.
If's NLA I'm in trouble because its gone soft on me and it isn't going to last much longer.
Regards,
Scott.
I think you can replace that with silicone vacuum line of the appropriate size. It's just the formed hose makes it easier. In hindsight I wish I had done that while it was all apart. Then I wouldn't have to worry about it. Make sure you do the idle control valve while you're in there. It's a PITA after it's all back together.
Regards,
Scott.
