Rear upper control arm
Is there supposed to be a gap between the washer and the rear upper control arm (or whatever it is called)? It looks like it should but the pin is shiny indicating the arm is moving around. The other side also has a gap but is not shiny. Anybody knows what is normal?
That's what I tought, thanks. It looks like in your pic there is some rubber between the washer and the arm, on mine it's not there. Is that part of the arm or a separate piece?
