1990 Timing Belt - Height of belt lobes
If anyone has a new timing belt can you please measure the hight of the semi-circular lobes from the inside flat section of the timing belt to the peak of the lobes.
The heights of different belt manufactures lobes would be a great help also.
I am currently investigating the different depths of the semi-circular teeth on the camshaft drive gears, the lub oil pump drive gear and the crankshaft drive gear, as I have gears that have wear on the outside diameter of the flat sections of the semi-circular teeth and I have measured different teeth depth on the gears mentioned above..
Thanks in advance for the help.
I measured a few belts
New Gates tensioned on the engine
5.60 MM total thickness
2.20 MM in the groove
3.40 MM tooth ht
Used Gates with 15 K miles off the engine
5.68 MM total thickness
2.36 MM in the groove
3.32 MM tooth ht
Used Uniroyal off the engine
5.50 MM total thickness
3.14 MM tooth ht
3.40 MM tooth ht
3.32 MM tooth ht
3.14 MM tooth ht
I have just posted the following message on a post titled Momgo's "First Time" - Timing Belt/Water Pump thread, as he is looking at the possibility of coating his aluminium camshaft driven sprockets.
This is a brief update on where I up to:
Currently in the process of having camshaft sprockets, lub oil sprocket and crankshaft drive sprocket for the the S4, coated with Cerakote Microslik C-110 ambient-cure ceramic dry film lubricant which is a division of NIC Industries Inc.
Address NIC Industries Inc
7050 Sixth Street
White City OR 97503
Phone: 541-826-1922
Fax: 541-826-6372
Web: www.nicindustries.com
They also have Creakote Microslik P-109, which is a baked on ceramic.
As per my previous recent thread on this subject, I advise that I'm currently undertaking a study/investigation on the timing belts' sprocket and belt geometry of the camshaft drive and driven sprockets, to ascertain what condition the camshaft sprockets need to be in to be suitable for refurbishment. This study will also try and ascertain the maximum wear limits of the sprockets and the clearances between belt lobes and sprockets.
I will also investigate whether the whole of the sprocket needs to be medium blasted or just the sprocket tooth area, thereby saving money.
I have actually seen camshaft driven sprockets that has been nearly completely worn down to slight "bumps" and the engine was still being operated. Unfortunately I do not have photographs of these sprockets.
The camshaft sprockets and belts are 8mm Synchronous Curilinear tooth HDT belt profile for the later MY 928s , whereas the older model 928s had Trapezoidal belt profiles.
At the completion of my investigation/study it is my intention to write up a full specification on how to prepare and coat the sprockets to be handed to the contractor for guidance (if required). from the surface preparation, racking, gas out, check list before spraying, spraying procedure and air drying or baking depending on what grade of Cerakote used and in addition some words on the belts geometry and the clearances between the sprockets and the belt lobes.
I would suggest that 928 owner don't choose any blasting and coating contractor. I will update my problem later in another post.
7050 Sixth Street
White City OR 97503
Phone: 541-826-1922
Fax: 541-826-6372
Tails - I've got a few brand-new cam gears on the shelf here too. Actually, thinking about it, I have brand-new of all the gears somewhere here..
I can bring them along to second-Tuesday on the 14th if you want to borrow them for measuring and comparing to the coated ones?
Tails, thanks for researching this this project.
I am wondering if it would be better to replace the crank drive gear with a fresh part,
instead of putting a slippery coating on this gear,
my concern would be that the slippery coating may cause the belt to slip off the gear should the belt have a loose fitting episode.
Of all the gears on the belt drive this one should not have a slippery surface IMHO,
infact you would want it to have some grip so the belt will not slip on the tooth flanks
Otherwise the recoated crank gear would make a nice paper weight for your desk.
Should you decide to not use it in your research
The oil pump gear has been superseded with a new steel gear and the rear 1mm shim should be removed before fitting the new steel gear
Hi Hilton,
I will bring along the gears that I have had done to compare with your new ones. Do you have a new belt as well, so we can look at the clearance between the belt lobes and the sprockets?
Hi Stan,
Thanks for your advice regarding the camshaft drive sprocket and also that the lub oil pump driven sprocket is now made of steel. Is the new lun oil pump sprocket coated with a ceramic coating?
If all alignment is correct there should not be any problems with the belt slipping off the camshaft drive sprocket. In some of the designs of these type of belts, the sprockets have flanges fitted to stop the belt migrating off the sprockets. These are usually fitted to extra ling indexing drive belts, not with automotive camshaft drive belts
It is imperative that the axial alignments of all sprockets, rollers etc., are in parallel and the vertical alignment is at right angle to the axial line and the sprockets and the rollers are in the same plane.
I have noted that some of the camshaft sprockets tops have worn and the wear indicates that they have been out of axial alignment, as seen by the differential of the depth of wear on the sprocket teeth tops..
When the sprockets have been renewed or refitted after refurbishment it is advisable to check the run out of the belt through the viewing holes in the camshaft covers as well. Any excess run out indicates out of alignment.
I believe that the re-tensioning of the belt after renewal is to allow for the wearing in of the belt and sprockets, which can cause loss of tension. I also fully subscribe that the belt tensioning should be carried out every 12 months to prevent “ratcheting of the belt” (climbing of the belt lobes up the sprocket teeth), which can occasion due to loss of tension. If the correct tension is not maintained it can cause failure of the belt or jumping of the teeth.
Regards,
Hi Stan,
Regards,
