timing pointer is bassaxewards.
glad you found the problems,
now hopefully after refitting the timing pointer on the WP then refitting the belt you have good compression on the all of the cylinders .
not sure i would run the engine first ,
rather turn it over by hand with the plugs removed to look for binding.
Turned it around now only 12 degrees off nice catch F/S this makes a lot more sense I am still going to 0 out the timing before I start still one or more teeth off.
