Wiring harness question from an idiot.
Ok, long story short (?):
'85 32v 5-spd. Had a fire last October, right front corner at 14-pin connector was the epicenter. Fried all three harnesses, hoses, plastic covers, tensioner etc. Got new (used) harnesses from Mark and Tom at 928 Int'l, lots of other parts from them and everybody else, etc. So, I have everything pretty much rehabbed, and almost ready to fire it up again.
BUT I'm an idiot and can't figure out where one last wire goes, on the engine harness. Branches off of the main harness before where the alternator wires do. Brown, I'm pretty sure, so it must be a ground? But I can't remember where to. I'm pretty sure I have the alternator wires correct, the two large reds and the smaller wire. I have the oil pressure sensor wires on and the oil level sender wire on. I've looked and can't find the answer anywhere.
Today I was able to dig my wife's '85 32v auto out of the driveway and get underneath it to look. And it's now more confusing because I can't find that wire on her car at all. If it is there it must branch off the harness behind the front engine cover, and on mine it's lower because of how I positioned the harness.
So I defer to all you folks with more 928 experience:
Is there a ground on the engine harness?
Could it be some kind of variation in the harness? Maybe it came off of an '86 or something?
Team Owner
that wire goes to the ABS block connection point ,
it routes through and in front of the driver side cam cover,
then under the ABS unit along the frame rail,
then up to the connection point next to the front of the power steering reservoir.
Its secured with a phillips head screw.
NOTE ..Warning this wire is hot all the time the battery is connected.
Make sure the battery is not connected till the wire is secured ,
otherwise you can weld the screwdriver to the fender
My guess is that cable has been originally red or yellow. In the harness there should not be any ground cable.
If yellow then it could be cable for starter solenoid, but it looks like too thick for that therefore I would propose ABS power cable, location front left just before radiator.
Do you have measured where is connected the other end of the cable. If starter solenoid then the other end is in 14 pin connector, if ABS the it is connected to harness +12V.
Thanks so much for all the quick responses!! And Alan you are correct, it is red. I thought I had accounted for all the red ones, and I had.
Mrmerlin, you're right, this must be the ABS wire. I just connected the battery, and it is hot. Problem is, I don't have ABS brakes.
So I will partially withdraw the idiot status. Just don't ask my wife.
So then, pevi, it connects to another hot somewhere in the harness, not directly from the 14 pin? I was hoping to disconnect the other end, but I guess not.
I definitely owe you three a nice, cold, Canadian beer!
Team Owner
AHH OK.... so this car your working on has no ABS,
but the replacement harness did come from an ABS car?
so now you have an extra wire thats hot?
Please take a picture of the hotpost and 14 pin connector
and the starter
and the starter
How is it supposed to be red or yellow? That would indicate a positive voltage source or B+, brown is commonly used in DIN/European makes to denote ground instead of black, although they use black to indicate ground too... bloody Germans.
In addition, I think your alternator fresh air housing (attached to the rear of the alternator) is clocked wrong. Looking from the rear (as in your picture), I'm pretty sure it should be rotated another 90 degrees clockwise. Then the fresh air hose will line up better.
Electron Wrangler
Alan
Thanks!
Thanks again, Stan. I'll check at the starter tomorrow as Alan said, and then if I can't find it I'll post some more photos.
Thanks again everybody for all the help!!
