928 Forum 1978-1995
Sponsored by: 928 Specialists
The infamous belt tension light and all it's attendent hilarity
Old 04-01-2013, 07:36 PM
  #31
Landseer
Landseer's Avatar
The 84 Euro I adopted has an early Pktensioner, installed 2008.
No worries!
Old 04-01-2013, 07:45 PM
  #32
Bjbpe
Bjbpe's Avatar
Response to docmirror
Methinks your choice of Pachelbel might emply blood and guts or thunder and lightning. Doe this imply that the installation of Porky is very difficult?
Old 04-01-2013, 09:03 PM
  #33
Randy V
Randy V's Avatar
Originally Posted by Bjbpe
After my most recent post, I decided to read Randy's comment about rebuilding the tensioner. This I have not done. Anybody want to provide instructions to do that?
Since you have replaced the timing belt yourself, can we assume you have the workshop manuals?
If so, instructions for rebuilding the tensioner are in that same section of the WSM.
Rebuilding the tensioner is easy compared to replacing the timing belt.
Old 04-01-2013, 10:03 PM
  #34
M. Requin
M. Requin's Avatar
Originally Posted by docmirror
A. Porkentioner is an after-market belt tensioning system. It uses more modern effect.
B. Call Roger at 817-430-2688, he will have that, and the other bits you need(if any for successful install)
C. No relation to Porky Pig.
D. Musical selection while install would be: Pachelbel of course.
But only use D flat below middle C! From Pachelbel's Canon, for example... actually, I forget which note it is, but I do use the tone, i.e. frequency measurement method, which as I am sure you know as a metrologist is what Gates et al seem to prefer these days. But the instruments they sell are a bit dear, so I just use a tone generator and/or guitar tuner, which works pretty well. (BTW, I work as a guide in the home of one of the greatest metrologists in US history, although Jefferson used the term "mensuration" back in the day. No rude jokes, please!)
Old 04-01-2013, 10:22 PM
  #35
docmirror
Shameful Thread Killer
docmirror's Avatar
Meh - not too hard. You have the skilz.
Pachelbel is about the most Teutonic composer from the era I could think of. I believe he trained one or both of the Bach's so maybe he knows something about composing.
Old 04-01-2013, 10:27 PM
  #36
Pfc. Parts
Pfc. Parts's Avatar
Now, here's the question;
1. Does anyone have a clue about this?
I've got the same problem as we speak. As Bill notes, one thing to check is the connection between the tensioner and the alarm. I found that when I'd replaced the belt covers last time the wire that runs from the outside of the center belt cover was broken under the insulation, which led to a false belt tension warning. The cable can't be much more than 22 gauge wire and in my case it's been sitting about an inch in front of a 300HP engine for the past 30 years. On top of that, there's no stress relief on the wire.
If anyone knows where to buy the male button connector that runs through the center belt cover I'd appreciate a reference.
Scott.
Old 04-02-2013, 01:46 AM
  #37
Bjbpe
Bjbpe's Avatar
Thanks Randy. I have all of the books.
Old 04-02-2013, 05:21 AM
  #38
Tony
Tony's Avatar
I'll deny it if questioned but I've tightened the belt just slightly past the reommended setting to get rid of an intermittent belt light.
SAY IT AINT SO!!!
you as well!
But..this was after i had set...then retensioned later...just needed a "tweek"..literally a half a turn and i never saw it again.
PKensioner has solved everything so far. Not many miles on it, but not easy ones either.
The strip of black tape on the cluster display helps as well...just kidding...just kidding!
Old 04-02-2013, 11:11 AM
  #39
SteveG
SteveG's Avatar
BJ, Pachebel (Canon at least) is about as far from blood and guts as you can get. Doc seems to have had another reason, but Pachebel is very soothing. Very good to help you remain calm and concentrate as you read the WSM.
RE: Belt job: Search is your friend. Lots of stuff here if you just take the time; An owner named Kelly has a manual for 85/86 on ebay, but very useful for all cuz it has lots of pics.
Pfc. : Holy parts trinity, Batman! 928Intl.com; 928gt.com; 928sRus.com.
Quick Reply: The infamous belt tension light and all it's attendent hilarity
