Question: Cost of bent valves
#31
Shameful Thread Killer
The car exterior looks good, the problem is it is an automatic the conversion to a manual would be a pain, maybe I would like for an automatic daily driver with a manual as a weekend (undecided)
"If" I buy it, it will be sitting on my street on jack stands while I work on it (SLOWLY) using information from here on Rennlist as a bible (aside from parts I need to buy tools too being I dont have metric nor even jack stands/engine crane etc, which slows down the process to a crawl which you guys dont recommend it).
If the car only has a bent valve then it makes it straight forward (aside from changing out the fuel tubes). It is the unknown which I am scared of.
This is not the car for you. If you don't have a garage, tools, jacks, 928 experience please find a good one to buy that only needs cosmetics, or small fixup issues. Or buy a good one from the classifieds here on rennlist.
#33
Yea I know, I would have to drop the car off at a friendly Rennlist member's place for the engine fixes (that should be quick tho being they know more than me).
If push comes to shove, harbor freight has Shop Cranes and engine stands for cheap.
Like I said, I got zero supplies to fix the car so the progress will be super slow. (at least I wont be doing it too fast that I screw up
Been really thinking of buying a more complete car (got some advice on who I can buy from), Jacks is more of a must buy (for just changing the oil and other minor maintenance stuff, but it is that engine lift that pretty much is the nail in the coffin)
#35
You really need a garage. I had mine up on stands for about six months. Just when you think you have all the tools you need. Damn I don't have the wrench for doing that job.
#36
The other part of the equation I find is that you go out and search for a car with all the mx up to date, the car looks and drives fabulous, it's shiny, and you notice all the trim bits are there, the wipers work, the hood stays open, the rubber bits are in good shape and you pay top dollar. They, two months after you get home, the valve covers start to leak, the AC takes a dump, you start to hear a whine from the rear axle, the int lights go out, the central warning lite comes on for no reason, and now you've paid real money for a car that you'll be working on anyway.
#37
I 2nd everything you said in this thread so far. Yes the key to owning any old car is working on it yourself. I suppose if I lived in Dalllas or someplace there was a 928 mechanic around it might be different. I did fix a a few bent valves a few years ago and it was not bad. Thanks to Sean for a lot of phone help. My problem was that I dropped a bit in the port when the intake was off and it got stuck in a valve. Mostly it was just my labor and about $350 in parts and machine work. Luckily I have a good machine shop that did the head work for me locally.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#39
Price this with Roger
16 ex valves
5 int valves
timing belt
water pump
Porkensioner
cam chains
tensioner pads
engine gasket kit
fuel line kit
vac hoses
timing gears(opt)
shop work
32 valve 3 angle job
clean 2 heads
surface 2 heads
load valves, seals, springs, etc.
If you get away under $2k it won't be by much.
16 ex valves
5 int valves
timing belt
water pump
Porkensioner
cam chains
tensioner pads
engine gasket kit
fuel line kit
vac hoses
timing gears(opt)
shop work
clean 2 heads
surface 2 heads
#40
If you are only comfortable with changing plugs everyonce in a while I think I would be looking for something else. The 928 is a great value for someone that is capable with a wrench. If you are set on a 928 in the end just budget $300 to $500 a month for repairs and upgrades after the purchase. That may work for you too but I just do not know your financial situation.
#41
I have no problems with wrench/screw drivers/electrics, give me directions or even just a diagram and I can do it without testing around. With no directions if I took it apart then reverse engineering by memory.
I have only done the basic maintance on a car so far, and I would not mind doing more tho more advanced stuff.. say removing an engine block I rather have a 928 owner with me![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The only car I hate to do an oil change is parent's honda accord being it is so bloody hard to get to the oil filter (maintaining a line of sight while trying to reach problem)
My monthly income isnt bad, its trying to figure out how much for the inital purchase without upsetting my family is the problem, but I think after everyone reasoning I think i will go for a car without much problems.
#43
There are a few more 928 guys in SD on the Pelican forum, many embracing buying cheap. Leo has a really nice $900 928 he lucked into, as well as a built from basket case car.
http://forums.pelicanparts.com/porsc...chnical-forum/
A different perspective and maybe more local resources for you.
#44
I had a TB failure in my '87 and had to decide if it was worth fixing. My mechanic told me 3K + 3k, minimum, worse if damage is not contained to top end. I'm pretty knowledgeable and good with tools, and most importantly, know my limitations. I decided to pull the heads myself to assess internal damage, rather than pay the mechanic $1500 to do it. I researched the job thoroughly and started. I had 12 bent intakes, no internal damage. 6 months later, I finished the job at a cost of ~$3500 including headwork (complete rebuild w/new exhaust guides + some repair work), specialized tools, new WP, chains, ceramic coat intake and VCs, new cam gears, gaskest//seals, injectors cleaned/tested, lots of other stuff I did because I had it apart. I was able to do this with the car next to my house, but only because I didn't have to remove the engine. If you're going to take this on, get a WSM and research the crap out of it. It can be done, but you really have to want to do it. It is very time consuming. Good luck!
#45
If you have minimal auto experience, but want a sport car, go buy an Eclipse or 300Z, you will be driving it much sooner.
