928 Forum 1978-1995
Sponsored by: 928 Specialists
Heater control valve
Old Mar 21, 2013 | 11:00 AM
ROG100's Avatar
ROG100
Basic Sponsor
Did some checking - with my main wholesaler in the last 12 months they have sold 756 and received 36 warranty returns. Manufacture has changed to Meyle (German) and on the bag - made in the PR of China.
We need to come up with a better mouse trap.
Old Mar 21, 2013 | 11:25 AM
Alan's Avatar
Alan
Electron Wrangler
Well since these don't seem to be a major issue for other domestic brands - are there ford/chevy parts we can adopt? The general configuration (vac to close) is the most common one - seems there should be multiple to chose from - need to match based on physical size, mount and hose connections. Then run the test mules - in 5 or 6 years we will have an idea on reliability...
Alan
Old Mar 22, 2013 | 03:27 AM
safulop's Avatar
safulop
And furthermore,
my shop's usual wholesaler (Worldpak) no longer has the 928 heater valves available. So the supply and quality are diminishing at the same time.
Old Mar 22, 2013 | 04:18 AM
Schocki's Avatar
Schocki
Talk to Roger, they are available from MB.
Old Mar 22, 2013 | 10:43 AM
928nut's Avatar
928nut
Alan
Here is my solution - 3 years and counting.
File Type: jpg
File Type: jpg
Old Mar 22, 2013 | 11:06 AM
Alan's Avatar
Alan
Electron Wrangler
Jan - great - a headstart on the testing phase...
Alan
Old Mar 22, 2013 | 11:22 AM
ROG100's Avatar
ROG100
Basic Sponsor
Unfortunatly 410073 was discontinued here in the States about three years ago. I still have a couple in the warehouse. It now supersedes to the same heater valve we are discussing. I will do a complete search this weekend for alternatives at all the main wholesalers.
Old Mar 22, 2013 | 11:30 AM
ROG100's Avatar
ROG100
Basic Sponsor
If you remember there was a metal version 410073 used on the Audi cars 74671 but again NLA and supersedes to the heater valve we are discussing.
Old Mar 22, 2013 | 11:31 AM
SMTCapeCod's Avatar
SMTCapeCod
And the metal part was a volvo app, right? I may have one in my basement somewhere 'midst the other spares.
For leaks, in addition to actuators folks should mind the condition of the pipe from the head as well.
Old Mar 22, 2013 | 11:35 AM
ROG100's Avatar
ROG100
Basic Sponsor
Sean I just checked the WorldPac stock and they have at least 100 in stock - your shop is probably trying to search using the 928 number. Tell them to use 000 830 57 84.
Old Mar 22, 2013 | 09:52 PM
waynestrutt's Avatar
waynestrutt
I am using a 12 v solenoid valve in place of the vacuum operated water valve. I take the 12v from the vacuum solenoid that operates the existing valve.
http://www.ebay.ca/itm/Electric-Sole...item51aa34cf9f
Old Mar 22, 2013 | 10:05 PM
Alan's Avatar
Alan
Electron Wrangler
Roger is sending me a metal version of 410073 to install and test.
Alan
Old Mar 23, 2013 | 12:10 PM
ROG100's Avatar
ROG100
Basic Sponsor
Wayne - very interesting solution and makes sense.
Care to share more info on the install please - size of hoses, clamping etc.
Roger
Old Mar 24, 2013 | 01:35 AM
ALKada's Avatar
ALKada
Under the specs pasted below, it gives a max fluid temp of 95 degrees.
Voltage: 12V DC
Current: 250mA
Pressure: 0 - 0.5Mpa
Valve type: diaphragm (operated by Servo)
Operation mode: normally closed
Inlet and outlet: hose barbs for 1/2" (outer diameter) hose
Max fluid temperature: 95 ˚
Usage: water and low viscosity fluids
The 12V solenoid valve is brand new and unused. Please note it is not suitable for use with gravity fed systems
Old Mar 24, 2013 | 11:30 AM
Herman K's Avatar
Herman K
Default US buy it now price...
$7.15 for the same item including shipping
http://www.ebay.com/itm/Electric-Sol...item19d2949560
Oops I just see this one says 24v DC I guess they can supply the 12V for the same price
