1 Inch wheel spacer pics ?
31mm ~ 1.25" hub and wheel-centric so no weight on the studs/lugs. Very happy with them. Factory 16x7" wheels with 225-50-16 Dunlop Dirrezza Star Spec's Factory ride height and suspension. And the studs are press-fit from the back, not dual thread in like others. My car's an '82 and didn't have the long studs or factory spacers. Hope this helps.
Before
After
Before
After
Got mine from 928 International. Others probably carry them as well.
About $250 for the bolt on ones. The slip on spacers require the longer studs, which require dissassembly of the rear hubs which means you also have to replace the rear wheel bearings....
James
James
