Steering pump question
Location: Wrong Island NY, 04 CTT , 1984 S 5 Speed Slate Blue Metallic
1 Post
I'm in the process of doing the 21 inch belt for the cooling fan on the new 84 but I'm confused on how to get the Power steering pump to move. I loosened the adjuster and the front bolt and the only other bolt I can see from the top is a large bolt that looks like it goes through the pump. Does that need to be loosened or do I have to mess with the alternator ? I am waiting on my service manual discs to arrive so hopefully I won't have too many more silly questions !
There is a nut on top, 13mm. Nut on bottom, 13mm and an adjustment bolt. Looses the first two and back off the adjustment and you should be good to go.
There is a mounting bracket on the back of the pump that is also a 13mm headed bolt but it should not keep you from moving the pump and access to it is from behind/above the alternator.
