Quarter Window install video
Had to replace a glass in Marvin and went ahead and video taped the process.
This is how I do it. There may be other ways to go about it. Feel free to add comments.
checkmate1996 (06-15-2022)
Great video, I think I'm going to need it. I'll replace the Vaseline with 94-12 GENUINE HONDA SHIN ETSU GREASE SLIDING SIDE DOOR ODYSSEY CR-V FACTORY stuff though to condition the seal at the same time. Thanks for the vid!
Vegas, Baby!
Great Vid, Dean!
Great video! I'm actually going to be replacing the trim pieces around the same window this weekend. It looked easier with the window out for sure, any advice on how to do it with the window in?
If it were me..I would pull the window and add the trim to the seal/glass out of the car. The glass can be pushed out at the top ( long leg ) from inside. It takes some muscle but that glass is tuff.
One thing I forgot to say in the video is as you seal the window the seal is PULLED down into the body. If you don't push the seal/trim as you go from the outside the seal will be PULLED right out from under the trim and you will have to start over.
I honestly have NO IDEA how the trim is added with the window in the car.
