Fuel line replacement and clamp clearance
Did anyone ever have issues with the clamps on the fuel lines from the rails to injectors interfering with the injector pigtail connector? I did a test fit and it appears that may happen. I will slide the clamps up higher to try to fix this. But...has anyone run into this? And why is there not a single picture of completed fuel lines to the injectors anywhere to show me how to orient the clamps so i know I'm in the ballpark???
This is on my 82 auto as well. I did have to undo the clamps and move them around a bit once I got it to the car but it fit like a charm with no issues. I'm sure someone else has a picture of them on the car.
-edit. I would recommend keeping the clamps a bit loose and test fit it in the car and move them so there is clearance. Then remove the fuel rail, tighten the clamps down, and you can install it into the car.
![](https://rennlist.com/forums/attachments/928-forum/609216d1329671072-so-what-did-you-do-to-your-928-today-imag0180.jpg)
