Need help troubleshooting blower motor
Either DEF mode & DEF relay or the blower Switch on high should make the blower run - both require the Blower Relay to turn on and Fuse #17 (HVAC Blower) must be good. Since neither works - I'd not waste any time on the DEF relay.
You need to do the tests Wally proposed to test the blower relay function. The small relay in the head unit can cause the AC not to work - but it doesn't cause the blower not to work... so deferr testing that.
In addition to what Wally proposed, assuming adding the blower relay bridge between 87/30 makes the blower run - then with the blower relay out - test pin 86 on the socket - it should go to 12v+ when the car is running with HVAC head connected and not in the "Off" mode. If this doesen't happen - you need to know why? this is the root of your issue..
BTW - are you sure you are removing & testing the right relays ...?? The labelling is not systematic wrt position - you must pay attention to the little arrows by the labels.... Lot of people didn't get this...
Alan
Alan
2) If you have power on Terminal 30 of Relay X, install a temporary jumper between Terminals 30 and 87 in the socket for Relay X. Try the blower switch. If the blower works normally, the Resistor Pack is OK. If the blower works only on the highest speed setting, there is a broken resistor wire in the Resistor Pack. If the blower doesn't work at all, there is a faulty connection somewhere between Terminal 87 and the blower motor.
3) If the blower works at all, remove the relay jumper and install Relay X in the socket and repeat the test. If the blower works exactly the same with the relay as it did with the jumper, you should now know what the problem is. If the blower does not work at all with the relay installed, swap Relay X and Relay VIII (the Defrost Relay). If the system still does not work, you probably have a failure in the HVAC Control Unit or elsewhere. The most common failure is the small relay inside the unit. This can be replaced.
It is possible that you have a problem with the cabin air temp sensor - perhaps the fan motor - but do the suggested tests first.
https://928srus.com/pages/charts
https://cdn.shopify.com/s/files/1/16.../1977-1979.png
Does this also happen with the AC turned off? Does it happen in high speed mode with the blower resistor unplugged?
The relay pins to jump are the same as wally noted: 87 & 30 or on the inset relay footprint on the diagram with all the fuses/relays & plugs: Pins 3 & 5
Alan
