Valve compressor tool
I do, was looking for the pic in another thread that covered this already as there are different tools that work. Note: you will also need to make a "tube" w/ slots out of Schedule 40 tubing to reach/press down into the Valve recess to remove the valve keepers. This has also been covered w/ measurements, I think I built mine based on one that Tony made.
Please try some searches too.
Dave
This one
http://www.sears.com/craftsman-valve...p-00947627000P
Dave
This one
the removal of the valves has been done on my car except for one. I had search ed last night but didnot find anything. ill do another search tonight.
I used a crewed way of removing the keepers. a socket and a hammer and allowed the valve spring to push out the keepers
thank u
thank u
I loojed around last night and coukd not find a thread about the re configuration of the tool.
I did see a few post from u and others about a few options.
here is one of them
End time: Feb 18, 2013 2:36:14 PM
Item: New T Handle Deep Valve Seal Remover Puller Tool 1243
URL: http://pages.ebay.com/motors/link/?n...d=370579563144
Alt URL: http://www.ebay.com/itm/New-T-Handle...-/370579563144
here is one of them
Took a bit of searching, here is the one I made.
Note: remember to keep the cut outs minimal as this will be under Valve Spring pressure and it needs to be strong (schedule - 40 CPVC, not pvc).
Also using the Plastic CPVC keeps you from scraching the Tappet guides.
https://rennlist.com/forums/928-foru...=valve+removal
Hope this helps,
Dave
Hope this helps,
Dave
Archive Gatekeeper
I have a Schley 91400A valve spring compressor tool set that you're welcome to borrow if you want to pay shipping both ways.
The depami angle:
The depami angle:
Devek9, thank you for digging out this old thread. I searched for about 45 minutes and found nothing about the tool.
Rob Edwards, you have a PM
thanks you
jpc
thanks you
jpc
I had a super tough time getting my valves out. I used a loaner tool from parts store. Did not work. No bought a studier one. Did not work as it kept slipping off of the springs. I bought the c- clamp style did not work.
What I finally did was to take apart the screw down type and connect it to a very large c-clamp. This worked great. Just have to make sure it's on Center.
I used a drill stand with powerdrill in it(not connected to power). A large 1/2" socket with extension into the power drill, and 1/4 cut out of the socket to access the half moons. Last time I used this was for a 356 engine so not sure if this will work on a 928 engine
Archive Gatekeeper
If anyone wants the best valve compressor for head-off use, there's a nice looking Snap-On CF-700 on Ebay at an excellent price. I have one, it's the shizznit.
http://www.ebay.com/itm/Snap-On-CF-7...191627&vxp=mtr
Captain Obvious
Super User
Super User
That's exactly what I used too on my '85 32V.
Hey, If you are looking for a solution related to compressor & valves then contact Zahroof valves. They manufacture innovative valves & compressors. They also provide simple yet effective solutions related to valves & compressors to increase their efficiency & reduce emission.
