cam sprocket 45 degree mark
I should know this but the grey cells ram has crashed.
From the TDC notch on the cams how many teeth away should the sprocket line up with the crank at 45 degree.
TIA
TIA
Cams rotate at 1/2 the speed of the motor.
So 45 deg would be 22.5 deg.
Now count the teeth on the cam gear, divide by 360, then x by 22.5 and you have the number of teeth.
Or rotate he engine to 45 then mark the gear.
If it's apart then 45 won't matter on the cams. Put them a TDC then rotate the crank back to the same. But you already knew that.
thanks for the input guys.....was hoping someone would know off the top how may teeth.......IIRC its 3 but will have to hunt through my folders of pics as I marked the S4 sprockets when last in there.
Yes, its apart for new belt, pokensioner, gear and oil pump gears, and new roger cam sprockets
