engine intall with headers on?
^^^^ i am game. i had to take install the engine, find out had messed up the rear main install, and had to drop the clutch WHICH means taking off the headers again.... etc..... UGH.....
the thing i do like about the MSDS headers is you can move each tube a little on the tight spots.
Motor is in resting on new motor mounts. what a battle. With new mounts as i lowered the engine they wanted to hang up om the oil pan. just enough that it wouldn't drop in. Finally had to crawl under with a small pry bar and pry them out just enough to get it started. Then she dropped in. Engine does sit a little higher now. Oh and I did manage to break the accelerator cable at the firewall. Gotta love thirty year old plastic. Time for a mental break. Still have to try and install the headers.
Gettin there. Just got the bolts in for the engine mounts. I think I'll take the exhaust manifolds off the old motor and test fit and tweak the the headers a little to make them go on easier. Might need to open up the holes a little. They were pretty snug coming off. Just have to keep reminding myself I have lots of time.
Just got the drivers side on. I had to lift the engine a bit to wrangle it in. When I got it on the studs and dropped the engine back into place this is what I found. The front pipe is sitting solid on the heat-shield. Does that look right?
thats what it did. split the lip at the bend, and a little on each side of the that. 1" down? made little flaps. just bent them back.
no worries on that rack. None at all
Heat-shields trimmed, all nuts and washers on. Now just have to tighten drivers side. Not a job made for people with bigger hands. Would also help to be a contortionist. Some studs you can reach from below, some you have to get from above.
Ok. While doing some more shaping on the heat-shield I found that one of the manifold gaskets had fallen out. What's the chances it will seal well without it? not really looking forward to taking it off again. even though the passenger side is easier.
Yeah, I decided it was worth the risk. Starting to out everything else back on. Just put the steering pump back on. Had to take the bracket back off to put it on. Seems like I've been doing a lot of that lately. Seems there's a sequence to everything.
