928 Forum 1978-1995
Sponsored by: 928 Specialists
CV joint?
Old Jan 27, 2013 | 05:45 PM
Gr8godbob's Avatar
Gr8godbob
Default CV joint?
Hi all,
It has been great reading all your accomplishments with your Sharks.
A question,
When i turn the steering wheel and move the car in reverse, there is a knocking from the front left wheel. The car also tends to pull left when driving along, ever so slightly, but just enough to be noticeable.
Do you think this is a CV problem, and wheel alignment?
Cheers.
88 s4
Old Jan 27, 2013 | 06:07 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
wheel bearing possibly. CV's are in the rear so i doubt that.
Old Jan 27, 2013 | 07:03 PM
17prospective buyer's Avatar
17prospective buyer
You have the rare AWD 928? Cool.
Check for things rubbing, like ABS harness/wires or brake lines.
Old Jan 27, 2013 | 07:06 PM
lonnie77's Avatar
lonnie77
Could be that the wheel alignment nut's are loose on the front left and is moving. Or a brake pad. Grab the top of the wheel and pull it and push it to see if it moves.
There I fixed it.
Old Jan 27, 2013 | 09:54 PM
928 at last's Avatar
928 at last
Default Really?
Originally Posted by lonnie77
Could be that the wheel alignment nut's are loose on the front left and is moving. Or a brake shoe. Grab the top of the wheel and pull it and push it to see if it moves.
Lonnie,
Glad to see you've got a tarp over the scene of the "accident".
You have "shoes' in one of your cars? really? and it has a Porsche logo on it?
My bet is on the wheel bearing......or the brake lines swelling.......or....
Old Jan 27, 2013 | 09:56 PM
928 at last
Sorry, should have qualified that......
It's a 928?....
Old Jan 27, 2013 | 11:01 PM
lonnie77's Avatar
lonnie77
I almost gave in on that one. The 928 does have brake shoes. You tell me where they are.
I was just thinking the "pad" is dragging causing it to pull to the left but without pictures...
Old Jan 27, 2013 | 11:44 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
.......... The 928 does have brake shoes. You tell me where they are....
"Bend over and I'll show ya!"
Old Jan 28, 2013 | 12:13 AM
928 at last
Default Fine, But....
Fine, but, we were talking about the fronts.....I didn't account for a sudden transition to the E-Brake set up....
Old Jan 28, 2013 | 12:24 AM
danglerb's Avatar
danglerb
When you have suspension stuff loose enough to make noise, don't drive until it s sorted out.
Old Jan 28, 2013 | 01:54 AM
FiveElements's Avatar
FiveElements
This is a treat I'd like to keep reviewing.
I get the same knocking from my left wheel area in reverse. I have check everything and all the alignment nuts are tight, the sway bar and A arm bolts all are tight too. When the car is raised, I pulled on the wheels and the bearings seem solid... You guys think it could be a brake pad shifting around? That seems a bit unrealistic since the knocking comes as I press the brakes to stop and they are gripping the disc pretty hard at this point. Is there a chance the A arm bushings are worn and the assembly is popping or shifting?
Old Jan 28, 2013 | 01:11 PM
Emickelsen's Avatar
Emickelsen
Sorry for the sidetrack. I was looking at your avitar picture, you doing that work by yourself, or is someone helping you?
Old Jan 28, 2013 | 09:51 PM
lonnie77's Avatar
lonnie77
What you think I have friends? I have replaced the transmission more than once all by myself.
Old Jan 29, 2013 | 03:54 AM
FiveElements
Done it once myself... not fun
