928 Forum 1978-1995
Sponsored by: 928 Specialists
Tow Eye Plug
Old Jan 23, 2013 | 02:54 PM
baystate928's Avatar
baystate928
Default Tow Eye Plug
Not a new story here. I have been fighting with my aluminum plug for the last few months. Seems that a possible combination of PB Blaster soaking for 2 months and painfully cold whether may have been enough to loosen the plug. So, yesterday I was able to get mine out. The actual plug was not as I had imagined it to look and since I could not find any pictures of the piece I figured that I would post mine. If I had know what was lurking behind that cap, I might have approached the job a bit differently.
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 23, 2013 | 06:30 PM
jpitman2's Avatar
jpitman2
Well done, havent seen an almost intact one before. Now get on Alan's list to use my tap to clean up the threads, and get a late model rubber bung to keep things clean for when you do need to use it !
jp 83 Euro S AT 54k
Old Jan 23, 2013 | 06:53 PM
CraigL's Avatar
CraigL
+1 on never having seen an intact one.
It is amazing that PB blaster was effective. Mine seemed to have become one with the frame.
Just a few comments: I wonder if drilling a hole through the cap and introducing PB blaster/Acetone-ATF/etc into the cavity behind the head and in front of the threads would be a good strategy for allowing the penetrant to do its thing. Lastly, using a 1/2 drive wrench is probably the fast track to snapping the hex bit off.
Old Jan 23, 2013 | 07:40 PM
fraggle's Avatar
fraggle
so THAT'S what it looks like!
Old Jan 23, 2013 | 09:02 PM
Randy V's Avatar
Randy V
25 Year Member
You got lucky in being able to remove it in one piece without mucking up the threads.
Old Jan 23, 2013 | 09:17 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
wow...... buggered up!
Old Jan 23, 2013 | 10:10 PM
SeanR's Avatar
SeanR
Finally put some effort in to removing mine and I am amazed that it came out. Sweet. Tried before and didn't put much force on it and I suppose that is what it needed.
Tried to do two others that are here and they were not going to budge.
Old Jan 23, 2013 | 10:15 PM
jayc67's Avatar
jayc67
That's on my yearly checklist. Remove plug, clean threads, coat in anti seize, reinstall and hope like hell I never actually need to use the eye.
Old Jan 23, 2013 | 10:41 PM
baystate928
One of the motivations for getting the plug out in one piece was to avoid the need to reform threads. There was a fair amount of debris in the threads but no major deformation. Just so that I didn't end up with a nasty surprise one day, I did test the threads by installing the tow eye. I was able to get full engagement without much effort at all. So, I have spray the threads with Corrosion X and will have the new plastic insert on my next order of parts. No big hurry as the car's winter slumber has another 2-3 months before the salt is washed off of the roads.
I really think that one of the factors was the temperature, as aluminum will expand and contract more than steel. May have been just enough to loosen the 2 parts up. So, kudos to Canada for sending down that blast of cold air! But I am good now so you guys can take it back any time..
Incidentally, here is my magic removal tool when all was said and done. Unfortunately, the screw driver was a sacrifice, but I'll consider it a fair trade for getting the plug out in 1 piece.
File Type: jpg
Old Jan 24, 2013 | 12:26 PM
Randy V's Avatar
Randy V
25 Year Member
Just buy the later rubber plug for a few bucks and be done with it.
Recommended for anyone with the original aluminum plug.
Old Jan 25, 2013 | 01:15 AM
danglerb's Avatar
danglerb
I'm thinking an impact driver might be good to try unsticking one. The manual types you whack with a hammer to make them twist.
Old Jan 25, 2013 | 07:21 AM
Leon Speed's Avatar
Leon Speed
Don't lube the rubber plug like I did, it was gone within a day. And yes, I mean the tow eye plug
Old Jan 25, 2013 | 12:44 PM
inactiveuser1's Avatar
inactiveuser1
Aluminum plugs into steel,aluminum ball joints in earlier cars.Not sure if that was too many beers for designers or not enough.
Old Jan 25, 2013 | 12:51 PM
finally!'s Avatar
finally!
and can paint the rubber one to match!
Old Oct 31, 2013 | 10:04 PM
jwbeck17's Avatar
jwbeck17
I've been coating mine externally with PB Blaster for a few weeks now and unfortunately just snapped the 6mm hex bit in the plug. Trying to determine what is the best next step here: to try to drill out the bit tip to keep the plug intact and continue trying to get it off, or try to drill out the entire plug. Or is there a better option?
