Lights
Is there a fuse for the headlights in the bumper that is seperate of the pop up headlights? If not, will both lights not operate if one has a blown bulb? Looked at bulbs in one and they were ok. Screws holding the other one in has been stripped out. How can I remove a Phillips head screw with the head stripped?
take some valve grinding compound and put it on the head of the screw then fit the tool ,
if the head is totally stripped then try to cut a slot to fit a flat blade ,
if that wont work get a drill and drill the head off the screw.
There is a fuse relay chart available at
www.928gt.com
look on page two under tips and links print one off, then you will have a fuse relay diagram for your car ,
there are fog lamp fuses
www.928gt.com
When I put a new fuse into slot for fog lights, it immediately blows. It call for a 15, I went up to 30 and it still blows. Any suggestions?
Any Suggestions?
Any Suggestions?
