New Wetwall Development Allows 7.0L+ 928 Engines
#92
Developer
That is correct - customer supplied engine.
I can supply a core engine to rebuild for $800 if you would prefer.
I have already discovered that $2240 price will not last (another invoice came in on this build) - it will soon be $2895.00. Now that all the parts and labor is done, I know that $2895 price is reliable.
If someone is ready to pull the trigger at $2240 I will honor that price for another month.
#93
I have been working up this 7.0L block modification, and it seems we will come to market with it at $2240. That includes: bore removing the cylinder walls from the stock block, boring the block to receive the sleeves, the sleeves, and installation of the sleeves. Decking of the block and sleeves when finished, jet washing the block after completion of all machining.
Expect to pay about $1400 for a set of quality custom forged pistons.
And you still need piston rings, inspection and polishing the used crank, a set of main and rod bearings, and engine assembly.
I'm sorry, but the $2000 mark is not attainable.
Kinda wish i didnt Powder coat the block i had with a split cylinder...could have had a second life for some one.
#94
There is also many more than one GTS in the world which has dead original engine block. As 928 becomes more collectable it important to have matching numbers engine. Even without big bore some solution like this is needed in future. Hopefully it works in long run also.
#95
Developer
If the cylinder walls are scratched deeper than that, I'd recommend our dry-sleeving process. We have the drywall sleeving iof the 928 block down to a science, and I could easily repair a GTS block with a badly damaged cylinder this way. We can go up to 104mm bore in dry sleeves. See post #2 of this thread.
#96
Archive Gatekeeper
How 'bout this GTS block, Carl?
This is one of those blocks that some day I will have repaired, in order to have the matching number block. But I'm worried about whether there's enough 'meat' left in the webbing for a sleeve repair.
#97
GTS blocks tend to have tower cracked all the way through to water area due to blown head gasket leaking water into cylinder and piston expanding. Sometime top inch is ok and crack is in middle of stroke. On others crack is all the way up to head gasket mounting surface. Bore wall is usually in surprisingly good condition. Dry sleeving is one option to fix this type of problem but block needs to be welded first and success rate on such repair isn't best possible. Wet wall repair might be better option as long as it works on long term.
#98
Developer
I used to agree with welding cracks in 928 engines, but not any more. Even using the correct Alusil welding rod, the Alusil is a bear to weld, and although the weld fillet held up, the heat effected zone to the left and right of the fillet cracked. On rare occasion have I seen the Alusil NOT crack after the weld cools.
That block looks probably worse than it is, IMO Rob. Could be drysleeved and that would remove all the damage you see in the bores anyway.
BUT FIRST - before you spend the money, have the block Zyglo inspected for cracks.
You can download the instructions for the Zyglo here:
http://www.magnaflux.com/NewsDownloa...?EntryId=13046
#99
Rob- if you have the block cracked checked make them check the entire block. Back in the CanAm days we had a sleeveless Reynolds 390 alloy (same as 928) 510 Chevy Big Block block that had rod damage similar to yours. Even though nothing had hit the lifter areas they were minutely cracked due to the high silicone content of the block being brittle and the shock of the rod transferring through the whole block.
Best to be sure. Probably the best place to get it checked is at an FAA approved repair station at an airport. They won't pass it unless it's O.K.
