4.5L piston ring set $179
Administrator - "Tyson"
Pelican shows the Goetz 95mm as NLA, only has the Deves:
http://www.pelicanparts.com/cgi-bin/...0%281980-82%29
I've never seen this brand before, at that price it's almost worth it to rebuild a 4.5
It says:
W/3.00 mm oil ring groove.
This sounds like there are other dimensions among the 4.5 L's. Perhaps these rings weren't actually designed for the 928 4.5L?
Are they used in Alusil cylinder liners? They list same ring set for all 100mm 928 pistons including GTS which is wrong due to 2nd compression ring design difference. If I recall right, this was informed to them year or two ago.
