928 Forum 1978-1995
Sponsored by: 928 Specialists
RE: Electric problem
Old Jan 18, 2013 | 06:54 PM
georges 928S's Avatar
georges 928S
Default RE: Electric problem
Hi Guys, can any body tell me what powers the fuse box is it a relay or some other power source. Thanks in advance. Ed.
Old Jan 18, 2013 | 07:05 PM
James Bailey's Avatar
James Bailey
the battery has a + cable which goes to the starter, another wire goes from starter picks up alternator and goes to the "jump start post" under the hood right side near radiator. Then wires go to the fuse and relay board and ignition switch....more or less
However the battery ground strap from the - post goes to a wingnut bolt that screws into the chassis behind the tool kit in the rear of the car. Often the ground strap is corroded inside and does not flow power. Also if you mention the problem you are having there are some very helpful people who might be able to help. Like if the car will not crank or dash lights will not come on......might be a bad ignition switch.
Old Jan 18, 2013 | 10:03 PM
georges 928S
Default RE: electric problem
Hi Jim, sorry i didnt tell you the problem is with my wifes car, witch is a mercedes C240 2002 model. i was checking the fuses with circuit tester powered by a regulated power supply when this happened, so i thought i blew a relay. after that i got a fault code whitch says (tele aid) and restraint system and visit shop witch means go to dealer witch i dont wanna do, if any one with trouble shooting exprience can help please do so. Thanks in advance. Ed.
Old Jan 18, 2013 | 10:08 PM
James Bailey
Sorry, I know nothing about Mercedes.....
Old Jan 18, 2013 | 10:39 PM
Alan's Avatar
Alan
Electron Wrangler
Not suprisingly not all cars are exactly the same - you can't assume anything based on how a 928 is wired - they are actually fairly unlike most other cars... due to the rear battery configuration.
Alan
Old Jan 19, 2013 | 12:41 AM
jpitman2's Avatar
jpitman2
try www.mercedesshop.com, forum for your model....
jp 83 Euro S AT 54k
