12-pin rectangular diag connector
Anyone have the Pin assignment (or a picture) of the Diag 12-pin rectangular connector (for an '88)
1 - Switched 12V
2 - MPIX ground
3 - RPM
4 - Knock
5 - 12V fused (fuse 24)
6 - n/a
7 - n/a
8 - n/a
9 - Hall
10 - K data
11 - Check engine
12 - L data
Pins 1 and 2 are both at the end by the plastic alignment pin. Its numbered like a race grid, i.e. first row: 1 2 second row: 3 4 etc.
2 - MPIX ground
3 - RPM
4 - Knock
6 - n/a
7 - n/a
8 - n/a
9 - Hall
10 - K data
11 - Check engine
12 - L data
Inventor
So
1 - Switched 12V = Black
2 - MPIX ground = Brown
3 - RPM = Black/Yellow
4 - Knock = Green
5 - 12V fused (fuse 24) = Red
6 - n/a
7 - n/a
8 - n/a
9 - Hall = White
10 - K data = White
11 - Check engine = Brown/White
12 - L data = White
4 - Knock = Green
6 - n/a
7 - n/a
8 - n/a
9 - Hall = White
10 - K data = White
12 - L data = White
Pin 10 and 12 were inverted ????
And the color is not the same on my car - all white cables are in fact brown !!!
Thanks for your help. Now my SharkTuner is working ....
But do you mean "brown" as in "previously were white" or really brown? I thought the factory was pretty careful about reserving "brown" for ground wires...
